I AM FITTING A 2LT PINTO & 5SP TYPE 9 GEARBOX TO A MARLIN SWB. THE ISSUE I HAVE AT THE MOMMENT IS I HAVE REMOVED THE OLD CLUTCH MASTER CYLINDER AND NEED TO FIT A CLUTCH CABLE.I HAVE A STD FORD SELF ADJUSTING CABLE.DOES ANYONE HAVE ANY INFO ON THIS OR A KIT TO FIT A ADJUSTABLE CLUTCH CABLE TO THE BULKHEAD AND HOW TO ATTACH THE CABLE TO THE CLUTCH PEDAL.
FORD TYPE 9 G/BOX CLUTCH CABLE KIT INFO WANTED.
Re: FORD TYPE 9 G/BOX CLUTCH CABLE KIT INFO WANTED.
Put the Master cylinder back and fit one of the slave cylinder kits available for ford clutches. If memory serves me right Burton Power do one that fits around the gearbox shaft, inside the bell chamber.
Hi Bob
There was an article in last edition of Pitstop on converting from hydraulic to cable by David Prowse [01736 762992].He basically took a Sierra clutch pedal quadrant assy and fitted it to the marina pedal,
