Rear axle angle
  • davea76
    • Aug 2021
    • 71
    Rear axle angle
    So, just rebuilding the marlin and noticed that on fitting the rear axle is angled down at the front quite a bit, this is not the slotted type axle so no adjustment, is this normal on marlins ?
    At the moment it is just a chassis with axles and engine but cant see therr being enough weight to make a difference added
  • ggrum
    • 782
    On the assumption you are rebuilding a Roadster there should be a tapered block fitted between the spring and axle to give the correct angle and ride height. This should be referred to in the build manual.
    • davea76
      • Aug 2021
      • 71
      This is a berlinetta with cortina mk3 rear axle
      • davea76
        • Aug 2021
        • 71
        All sorted, turns out the springs i bought in good faith are not mk3 as free length is 13.5",
        now need springs
          • 903
          Burton Power have the correct springs.
          • davea76
            • Aug 2021
            • 71
            Thanks, dont suppose there's anywhere that sells them in red ?
