Marina Roadster polyurethane bushes
  • martinclan56
    • Feb 2020
    • 486
    Has any one else tried fitting polyurethane bushes to the front suspension eye? The one that mounts the lower arm to the chassis.
    The bushes I have (Superpro?) have a substantial shoulder on either end making it pretty much impossible. With other cars that I have used this type of aftermarket bush on they have been split - that is you insert them in two halves, one from either side.
    Cheers, Robin​
    Yes - it's not easy..!
    Mine were from Superflex; a big vice and a large socket or 2 was how I eventually managed (plus many profanities!).
    • Ye Ol Ripper
      • May 2016
      • 298
      Try purchasing some long possibly m12?
      threaded bar( ideally high tensile) but check the bushes holes diameter in case you need to use a smaller diameter threaded bar, 4 corresponding nuts(2 to back up the other 2 two nuts that will be put under pressure) & use 2 x 1/2" drive sockets to press them in.
      I am also unsure of your bushes outside diameters, but perhaps a Cortina / Sierra void bush tool may also work?
      Try using eIther fairy liquid or some thin oil applied inside the metal hole ,as this may help when fitting the bush.
      • martinclan56
        • Feb 2020
        • 486
        In the end, much to my surprise, it proved easy. I used the threaded bit from an old 3 leg puller which has an acme thead (better for pulling than a normal thread)
        Soaked in very hot water first and plenty of the supplied grease.
        Imagesuspension eye bush 1 by Robin Martin, on Flickr
        Imagesuspension eye bush 2 by Robin Martin, on Flickr​
          • 686
          Luvly jubbly... as someone said.
