I bought a new (to me) Sportster a few weeks ago Yesterday I went out for a blast with my wife as passenger (her first time out in it). To be honest, on the bumpy country roads around here, the handling was very challenging and not at all confidence inspiring, amd my wife did not enjoy the experience one bit! One reason was that I have just fitted new tyres and they were over-inflated. I asked the fitter for 24psi, but when I checked they were all at 32psi; so that didn't help. I stood there staring at the front end geometry, and noticed that to my "eyecrometer" there seemed to be far too much negative camber; seriously, noticably too much. I took some measurements using spirit level and ruler, and using my basic schoolboy trigonometry I worked out that front left wheel had 4.5 degrees of negative camber, whilst the front right had 3.6degrees.Way. way too much! For a fast road car I would not have wanted more than 1degree negative. It's almost as if the car was set up for lapping Silverstone (and then some!)
I then checked the rear camber. Both wheels have 3.5degrees negative . Again; way too much! So now I need to adjust those top front wishbones (luckily they are adjustable) to give me the required camber. How one does the Sierra-based rears is anyones guess! It's not a system I know at all, having been used to live axle hillclimb and sprint cars. Advice and comments most welcome! Thanks Chris.
