tining marks on crankshaft pulley
  • kolmershlagjp
    • Dec 2015
    • 180
    Hello
    I'm trying to find the timing marks on the crankshaft pulley.
    The fitted pulley doesn't seem to have a notch on the outer edges at all. Am I looking in the right area?​
  • martinclan56
    • Feb 2020
    • 484
    The Marlin Roadster was fitted with all sorts of engines. Before anyone can answer they will need to know which engine you have.
    • A_Hogg
      • 338
      Believe from previous posts it's a 1300 . Notch could be covered by paint or road debris. Try running your finger around the pulley , you should feel small depression
      • kolmershlagjp
        • Dec 2015
        • 180
        yes Morris Marina 1300 there is a small hollow on the pulley .the hollow would be the small depression?
        • yousay54
          • Aug 2018
          • 90
          Hi Can you tell me the nut size on the crankshaft pully nut, thanks.
