Hi, all. I'm part-way through my Sportster build and researching fitting a windscreen. Can anyone tell me what the brackets that fixed the support uprights each side of the screen itself to the chassis look like? The screen sits within the left and right stainless steel supports but these disappear into the GRP body panel so I can't tell what the ones Marlin supplied with their kit looked like. Does anyone have pics or an example, please? Thanks!
Sportster windscreen mounting?
There are some details on my windscreen install here:
Found a couple other photos in my archive, attached. However I remember making new ones as these were pretty flimsy from the factory. I'll grab some pics next time I'm in the garage and post up.
_MG_5249.jpgBMW E30 Sportster 2005 - M20B28 - Build Log and Updates http://www.msportster.co.uk/
http://www.modelog.co.uk/
http://www.mustang67.co.uk/
Passenger Side, this is a custom bracket - flatter than the supplied one
Driver side uses the supplied bracket:
IMG_3766.jpg IMG_3767.jpg IMG_3768.jpgAttached FilesBMW E30 Sportster 2005 - M20B28 - Build Log and Updates http://www.msportster.co.uk/
Patrick - this is excellent, thank you very much. I'd already looked in your invaluable build site and agree the OEM straight bracket seemed flimsy for the leverage that will apply to it so your custom fabrication confirms the correct solution. No need to go to any more trouble but if you could get a chance to measure the distance between the bolts holding this bracket it would allow me to set my screen uprights at a sensible angle!
Best wishes, Mark
