Self cancelling indicators
  • FranklinLeicester
    • 380
    A little problem has crept to the top my to-do list after 25 years! On my Marina based Roadster the self cancelling indicators have never worked properly and I’m not sure what to do about it. On coming out of a left hand bend or corner I nearly always have to cancel manually unless it’s a very tight corner but coming out of a right hander the cancellation is immediate. On a scale of car problems this is very minor but sometimes it’s annoying to notice the flashing light some time after rounding a corner. On taking the steering wheel off I notice 2 short prongs on the back of the boss. These locate in 2 gaps in a plastic bush on the column which I assume is something to do with self cancelling. That’s as far as I’ve got so far as I’m reluctant to monkey about with it before getting an expert opinion. Any experts out there?
    Franklin, Leicester
  • TVRFan
    • Jun 2022
    • 40
    First thing that strikes me is that if self cancel works for small turn one way and takes much bigger turn the other, then the steering column inner is not 'centered' when wheels are straight forward. So it may just need column UJ disconnecting and reset (i.e. column turned a little).
    There is a 'tab' of some kind for self cancel and this tab should point to the centre of the indicator stalk mechanism (at least on all the ones I've seen, designs vary a bit).
    If you are not sure exactly how self cancel works, jack up the car just enough to take weight off front wheels (use wooden blocks, NOT just a jack!) Then watch how self cancel works when you turn the steering wheel.
    That should give you info you need to sort it out.
    • FranklinLeicester
      • 380
      Thanks, that sounds logical, I’ll give it a try. Anything to avoid taking the stalk mechanism to pieces.
      Franklin, Leicester
      • Ye Ol Ripper
        • May 2016
        • 294
        There will be no need to take touch the internals of the stalk. I strongly recommend not doing so as tiny ball bearings that are spring loaded can fly out and disappear never to be seen again.
        Due to my stalks for the wipers and indicators being faulty when I first began recommissioning my Roadster.
        I researched and obtained classic mini replacements but importantly as my daily driver has the indicator on the left & wipers on the right i.e. The opposite orientation to the Marina .
        I wanted to standardise that so replaced them with the same orientation as my daily . I purchased them from Minispares, as after researching I discovered some Mini's were made with the indicators on the left and wipers on the right, which matched what I required .
        The plug in sockets are the same as the Marina.
        This was fitted on the right hand side of the steering wheel for all overseas cars and on UK cars from 1984 -89.
        As I didn't have a tiny bore micro bore bender , I then bent the 2 operating arms over my thigh . So that they missed the dash board top edge.
        • FranklinLeicester
          • 380
          Yes, I fear the explosion of small parts when messing with spring loaded car parts. I’ve had a look at the column/rack/uj area and I think I’ll just put up with it for the time being, but thanks for the advice.
          Franklin, Leicester
            • 590
            Over the years the position of the indicator stalk moved its angle of dangle on the column. Early cars had them pointing upward and later cars had them horizontal. As these Lucas stalks were used across many different cars over the years, Lucas had a colour coding for the different centre spindles/bush that cancelled the stalk to accommodate the different fittings. It is actually a very simple mechanism. A lug on the plastic bush pushes on the stalk when in the on position ultimately "pushing" the stalk back to neutral. All you need to do is cut new slots in the plastic bush (yours is probably the white one) to align with the steering wheel pins. Take off the steering wheel and keep turning the bush clockwise and anticlockwise to cancel the stalk. You will soon find the sweet spot that positions the lug on the bush in a central position, therefore giving you the same degrees of rotation for left and right corners. Position wheel back in place (making sure wheels and steering wheel are all pointing in dead ahead position), mark where the pins hit the plastic bush, them cut new slots to align everything. Voila....
            • FranklinLeicester
              • 380
              Yes, my plastic bush is white and it did occur to me that the problem might be related to the pins and the slots. I’ll give this some time and see what I can do with it.
              Franklin, Leicester
                • 1633
                I would go back to basics. Centralise the steering rack and see which way the steering wheel boss and self cancelling mechanism is aligned. Check that with the rack centralised the wheels are pointing straight ahead. Maybe the steering arms have been adjusted with unequal lengths which whilst giving the correct toe in, have rotated the wheel boss. If your steering wheel is attached to the boss with screws like a Motilita is it possible to re-time the boss on the splines such that the self cancelling is symmetrical in the straight ahead position. Then refit the wheel to the boss in the straight-ahead position.
                • FranklinLeicester
                  • 380
                  OK, I haven’t done anything since Jon’s post but I’ll use this info as well when having a good look see. I have a custom made steering wheel with an easily removable centre piece which gives access to the spline nut with a socket. I’ll get back to you in day a or so.
                  Franklin, Leicester
                  • FranklinLeicester
                    • 380
                    Sorted! Jon’s instructions were spot on. The job took less than 10 minutes including jacking the car up. Not sure but I think my wheel has been 180* out all this time. Anyway it cancels instantly both ways with equal turns. Just one thing, if it had been necessary to cut new slots in the plastic collar, I’m not sure how this would come out because mine didn’t yield to pulling. Anticipating this I would have drilled new holes on the back of the boss and moved the prongs into them.
                    Thanks for all the comments and interest.
                    Franklin, Leicester
                      • 1633
                      Glad you have sorted it.
