Just fitted an Oselli-tuned MGB lump (with Marina flywheel/clutch etc) into my Roadster as a replacement for the Marina TC item. However, i've tried two Marina (mechanical) fuel pumps but i can't get the fuel flowing. Fuel lines are all clear. I'm begining to think that maybe the rocker lever is not being activated by the camshaft.
Can someone advise - I know the MGB had electric pump but is the camshaft same as the Marina? Does it have a lobe to drive the rocker arm?
Or should i just switch to an electric pump? If so, any recommendations as to what type?
As always, help would be appreciated!
Cheers. Bruce
Cheers. Bruce
