hello i would like to install an electric fuel pump on my roadster marina 1300 carburettor su hs4 can you advise me for the material and the installation thank you
electric fuel pump
Tags: None
Have a look at Merlin Motorsport. Solid State (cube) Pump kits. I fitted one to my Classic car a few years ago and it totally eliminated vapour lock!
Check what pressure you need for twin SUs. Note the need to fit a pre filter and to use rubber bobbins to reduce noise. Also note the use of an earth wire across the rubber bobbin to ensure electrical continuity.
Links below:
Facet Cube kit.
Genuine Facet 'cube' type fuel pump kit. 12 Volt use and good for 3 - 4.5 PSI. Facet part number 40105. Large stocks available to buy online, over the phone or in store.
General info.
Facet Fuel Pumps - what's the difference between the Solid State, Cylindrical and Posi Flow pumps? Read Merlins article
Peter.
