Tyre pressures
  • Berlibrian
    • Jul 2024
    • 9
    Tyre pressures
    Hi what are the recommended tyre pressures for the Berli please?
    I have tyre size 215 70R 15 fitted
  • A_Hogg
    • 338
    If you use the search facility [top right hand] you'll find answers to most questions relating to the various models of Marlin. Try 22 psi all round as a starting point on a Berli
    • Berlibrian
      • Jul 2024
      • 9
      Thanks
      • B_Williams
        • 103
        I run 22 front 18 rear on mine, which was the recommendation of the chap who built it, and who had done extensive testing.
        Seems to work fine, without excessive tyre were on either the centres or the shoulders.
        Best Wishes
        Bill Williams
        Berlinetta
        • MOC Chair
          • Dec 2022
          • 225
          I find that the front tyres are better with a pressure lower than the rears. It also depends on the tyre size.
          l have 185/80 x 15 fitted and normally run with 20 front and 22 rear and increase to 24 rear when towing our caravan.
