Dashboard removal
  • rhysnolan
    • Jul 2023
    • 139
    Dashboard removal
    While this site was down I asked on FB about removing the dashboard later in the year so that I can refurbish the burred walnut.
    It's not too hard to figure wiring connections, speedo cable etc, but it there a trick to actually getting the dashboard out?
    I can see the bolts, but my issue seems to be how the top tucks up beneath the cowl and how the steering column prevents it being tipped to pull out.
    Help, in advance please!
    When I fitted a new dashboard I had to fiddle with the steering column hole so I had enough clearance to tip the dashboard back and get it over the column (- steering wheel of course)
    • A_Hogg
      • 338
      No easy solution as it's all down to the original builder or if it's been replaced. The steering column MAY have been fitted after the dash - who knows? Trial and error and perseverance is the key
      • rhysnolan
        • Jul 2023
        • 139
        Thanks folk.
        • rhysnolan
          • Jul 2023
          • 139
          Since I managed to fold myself under the dash a bit more than I usually can I found more fastenings and brackets at the sides close to the bottom. Can I unfasten them? That doesn't look easy!
            • 1237
            What you need to keep in mind is that although there is a simple, basic build manual each builder of any kit car has a free hand . However in answer to your question, I would suggest that anything that has been put together can be taken apart.
            Perhaps not in a re usable condition!! You may have to replace/ repair parts but this is what Kit cars/ Specials are all about in my opinion. Having seen photos of your Morgan project I am sure you are more than capable. Enjoy Danny
            • rhysnolan
              • Jul 2023
              • 139
              Thanks for the confidence Danny. If I could sell the Morgan....
