Steering rack nearside bush
  • wilkywoo
    • Dec 2025
    • 29
    Anyone know where to get the right one from, loads of play in nearside front wheel so took the gaitor off the tie rod and there is no bush in there so flapping around.
    I can find them for lots of cars but not for the marina rack?
  • A_Hogg
    • 338
    Marina owners club - Chris Weedon is the man to talk to as he usually has a stock . I made my own [ not quite true] My dimensions and guy at work machined one up .
    • martinclan56
      • Feb 2020
      • 485
      Assuming your car is RHD, there isn't a bush on the right hand side of the steering rack as the steering pinion holds it in place. There is a bush on the left hand side which is a common failure.
      I would be tempted to strip the steering rack down and see what is going on....
      • wilkywoo
        • Dec 2025
        • 29
        Sorry I meant the nearside, I found the correct bush and changed it yesterday. All well with the steering now.
        • A_Hogg
          • 338
          He actually states nearside one
          • martinclan56
            • Feb 2020
            • 485
            But says right as well! English language can be a pain. I guess he meant right as in correct not as in left or right!
            • martinclan56
              • Feb 2020
              • 485
              Well done. That bush is an absolute pain to do as I know from experience. Mine fell out again and I had to improvise the fixing of it!
              • A_Hogg
                • 338
                Perhaps we should use port and starboard to determine or simply nearside/offside! Maybe I was lucky but don't recall replacement being that much of an issue once rack is off the car.
                • martinclan56
                  • Feb 2020
                  • 485
                  I found the ball joints, which are peened, were a real pain to sepperate. I fixed the new bush using the original self tapping screw but it wasn't enough. I think I ended up drilling another hole and adding a second screw. Maybe I was just unlucky.
                  But....
                  In the end I was very lucky as I found a NOS rack on Ebay for not a lot of money so used that instead! So now at least I have a spare.
                  • wilkywoo
                    • Dec 2025
                    • 29
                    I drilled two little holes in the rack and used a pair of screws.
                    • wilkywoo
                      • Dec 2025
                      • 29
                      But....
                      I didnt remove the balljoints, just undid the inner tierod with some big pipe wrench.
                      • Ye Ol Ripper
                        • May 2016
                        • 297
                        When I fitted the steering bush supplied by Chris Weedon of the Marina club. I followed a fitment guide on their forum. I drilled and just used 1 self tapping screw but cruicially following the guide , i cleaned/ degreased inside the rack where it was to locate. I then used RTV silicone sealant by Granville in a 300 ml tube to assist secure it both on the poly bush and inside the hole.
                        I had no issues using that method after 6 years of use , the rack excessive play was sorted.
                        I did notice the steering full lock on one side differered to due to the bush, but that never caused an issue driving the Marlin.
