Alternator tension bracket on DOHC
    I've rotated the alternator lugs by 120 degrees to make it fit onto the n/s of the car, but at the momnet I can't figure out a good solution for the alternator tension bracket.
    There does not seem to be any good points to mount the engine side end.
    Any suggestions?
  • pdm_engineer
    • 86
    Re: Alternator tension bracket on DOHC
    Chris
    You will have to make your own bracket from at least 3mm steel, overwise it will snap, and bolt to one of the lower water pump fixings.
    Can't post the picture at the moment as there is something wrong with this facility.
      Peter, if you could email me a photo I'd be grateful. The address is chris.cussen(at)talktalk.net
        Thanks,
        This is my solution.
        Only Propshaft to fit and check out the wiring, then I should be able to fire it up
