Marina Parts - What are they?
    • 2447
    In the build of my Marina based MK2 SWB Marlin Roadster I have found these. Now, in the experience I have gained from this part built car, anything painted in Hammerite Green is to be used. My dilema, I don't know what these bits are for?? Can anyone help please.
    Re: Marina Parts - What are they?
    From left: Reaction pad from front suspension upper swivel pin , middle is the spring mounting plate from rear suspension. Don't recognise the third image
      • 2447
      A mate has just said the third one is the mounting plate for the front engine mount for a Marina. Thanks for your help.
        Now I recognise it!
        • AndrewKB
          • 124
          Are you sure about the third one? I'm away from my car at the moment, so can't check, but it looks more like a part from the front suspension to me.
            • 2447
            Hi all and many thanks for your help. I will not bother keeping the piece in the first picture as the Mini Nylock nut replces this. The second pieces I will keep although the car has a set already fitted, but you never know. The third piece is definately the off-side mount which fixes to the engine and then the rubber mount fits to the chassis. I will keep this and use it as a replcement as the one on the car if a tad rusty. Once again thanks for all your help. Adrian.
