Track-rod ends
  • trevor_ford
    • 213
    Track-rod ends
    Now I'm onto the front suspension tidy-up, the track rod rubber boots are perished. Can I replace the boots or should I replace the whole item? If I'm replacing the whole thing, are they Marina specific or generic items and what is the advantage of rose-jointed items? Thanks in advance to all the knowledgeable folk on this forum - what would I do without you !!
    • 2447
    Re: Track-rod ends
    You don't normally have to replace the trackrods unless you have been driving round with little or no bushes. If they are ok? just replace the bushes with SuperFlex ones.
      Re: Track-rod ends
      Trevor
      Assuming we are singing from the same song sheet - see item 220101970881 on e-bay
      • trevor_ford
        • 213
        Re: Track-rod ends
        Alan, we appear to be singing the same song and I've just bought the item, thanks. How come I couldn't find any when I searched !!
        Adrian, I think I'm getting even more confused. I've seen track-rod ends described as tie-rod ends and I think the trackrods you are meaning are what I thought were tie-bars ! I have got replacement Superflex bushes for these and also replacement bars as they have obviously been loose and have partially worn where they pass through the bracket behind the front bumper.
          • 2447
          Re: Track-rod ends
          Word blindness, tiredness, who knows. Sometimes I wonder what planet I am on. Mind you I had just come back from a day trip to Cumbria to pick up a gearbox. Anyway just ignor my ramblings, one day I will get up to speed with the rest of the world.
          • artrider50
            • 208
            Re: Track-rod ends
            Careful of 'rare' parts on eBay - track rod ends are freely available off the shelf from your motor factor - about £4 each I think mine were
              • 2447
              Re: Track-rod ends
              Back in real time. I agree with Chris I bought mine from AllParts £3.75 each. Always a good idea to see if parts are available off the shelf first. Even managed to buy my TIE-BARS (and this time I mean Tie-Bars) from AllParts as well.
                Re: Track-rod ends
                Thetrack rod end screws onto the end of the steering rack is very common part. The rubber boot on the track rod end is replaceable and most local factors have a card with various sizes on, as long as you can slit the taper joint without murdering the collar where the boot seats you will be OK .
                • trevor_ford
                  • 213
                  Re: Track-rod ends
                  Thanks guys, unfortunately my favourite local motor factor closed recently taking with them their dust laden stock of "Marlin parts" and friendly staff. The local Partco staff look at you kinda weird if you mention "Marina" - hence eBay is an easy option.
