Re: Steering column UJ - where to get?
Thanks Brian.
As it happens, I can thoroughly recommend David Manners (website has similar name) who delivered one in a day for £24 all in.
CHEERS TO ALL - now fitted, and awaiting MOT!
Phil, FYI, this is as much info as I can extract from the part (the old one was pressed-steel type, whereas the new is forged):
Overall length: 77mm ish
Hole dia: very near 14mm to outside of spline teeth.
No of splines: 36 (best count... done by pressing blue-tak around the splined end, and counting the indentations. Don't forget actual knuckle (female) will have fewer due to expansion slot, etc.)
Old - pressed steel - part has 'NACAM' and '4536' on it. New part has hard to read stuff, but seems to include: '3', '1/2', 'PS81' but it's all difficult to make out.
Hopefully photo attached of both parts.
Thanks Brian.
