Marina Based Roadster Assembly instructions
    I have found a full set of original instructions (typed version) It's a bit tatty but it is all there. Anyone want them? If so all I require is your name and address and I will send them.
  • tymill
    • 130
    Re: Marina Based Roadster Assembly instructions
    Hi Adrian, if you'd like I can scan them in and put them online for everyone.
    Early triumph-based manuals are already available on:
    www.tiyen.com/moc/
    Cheers,
    Ty
    my email address is the letter "t" then the at sign then "tiyen.com".
    • ajgcurtis
      • 32
      Dear Adrian
      I would like to take you up on your offer of original instructions for marlin roadster, My addres is Cleave fm Upottery Honiton Devon EX149QT I would be quite willing to copy them if anyone else required same at any time forward
      Many thanks Andrew Curtis
        Ok, what I'll do is copy them in word/PDF and send them to Ty and then I will send the originals to Andrew. Is that ok with everyone?
          OK Guys done. Ty should be in your inbox and Andrew will post on Monday. Happy reading. Adrian
          • tymill
            • 130
            Thanks Adrian, the manual is now online. Cheers!
            www.tiyen.com/moc
            Regards,
            Ty
            • ajgcurtis
              • 32
              Many thanks ,As said befor any copies needed I can send
              Cheers A
