breather on marina axel casing.
  • bobandjaneburden
    • 38
    hi, the breather is loose in the casing. how do you get it out? it just turns round,i need to tighting it as some oil has come out.do you just pull it out/push it in?.did not want to break it !!. thanks for any info.
  • tony.branson76
    • 81
    Re: breather on marina axel casing.
    Hi, It's threaded into the axle casing. It is in 2 parts, the bit that is threaded (sort of funnel shaped) and a cap that fits over the top. Are you just turning the top which will rotate on the funnel bit? I'm surprised oil is leaking out, is the axle over filled.
    Tony
      If you do require a new one they can be obtained from Rimmer Bros - see the Triumph dolly catalogue
      • trevor_ford
        • 213
        Bought Dolly breather cap - seems to be wrong thread size - too big. Doh!
