what is the best way to set up adjustable shocks to get the best alround ride from a roadster. i have a 1300 marina based car and the ride is vey hard, what tyre pressures are recommended many thanks john
adjustable spax
Tags: None
Re: adjustable spax
Hi John, My car is a hybrid with a 6 cyl so its a bit heavier than your car. But I use only 1 click front and 2 on the rear and that is with quite old units. I would back them right off then take the car on good run round then try turning up a couple of clicks and doing the same route again. Dont go too soft on tyre pressures as you will fing the car will bounce around on the walls. You need the suspension to work unless you enjoy driving a go cart.Ben Caswell probably not the last word on anything here!!
