Recently, my otherwise good hand-brake went on strike and failed to hold my Berli on a modest incline. Obviously, something had gone wrong and no prizes for guessing at a weeping slave cylinder & oily shoes on one drum (the second one I pulled off, of course!).
I obtained a pair of slave cylinders & a set of shoes without a lot of bother from my local car discount shop - Girling slaves (notable by having 2 threaded holes positioned horizontally), and 9 inch shoes per 2000cc pattern.
No particular problem in dismantling, cleaning drum & backplate, fitting the new slaves & reassembly with the new shoes. My problem, and hence my enquiry in this message, is that my old shoes did not have the auto-adjustment ratchet mechanism attached to the old shoes. (see copy of diagram in my Haynes manual). So without the auto bits, there are 2 ways of making an adjustment:-
1) the hand-brake lever connecting the 2 shoes next to the top spring, has a notched wheel that causes the lever to get 'longer' or 'shorter' when the wheel is levered using a screwdriver, and
2) the large adjusting nut on one of the handbrake cables under the car.
My first thought was to get the connecting lever inside the drum adjusted, but without a hole in the drum, I have to resort to removing/replacing the drum and adjusting the lever length by trial & error. Then once the drum rubs on the shoe-lining (probably will operate the hand & footbrake at intervals throughout) I would back off the adjustment a smidgen, and leave it with the drum freewheeling without hindrance. Once the second drum has had the same treatment, I would concentrate on adjusting the cable.
Anybody got any tips or different ideas?
Also, why haven't my rear brakes got auto adjusters per Haynes 1976 - 1982 - see Image 1 ? Did the original builder junk the adjusters, or what?
