Looking for 8 studs (for wheels!)
  • KitCarGirl
    • 720
    I recently had my back axle wheel studs replaced as the existing ones are a tad short now I have my posh alloys. I had 8 studs donated to me from Peter Hoile in South Woodham Ferrers and I ordered 8 more off eBay. BUT, the eBAY ones were too long.
    I need (approx) 45mm length in total and the spline needs to be 10mm, not the 17 - 20 mm that I only seem to be able to find everywhere.
    Does anyone have any lying around? Anyone got a decent link I can try 'cos I'm getting fed up looking now.
    The left hand stud is about 38mm in total length with a 10mm spline and the right hand stud is about 52mm with a 20mm spline.
    I'm looking for a length around 45 mm but the spline has to be 10mm.
    Help if possible please!
  • cabrioman
    • 309
    Re: Looking for 8 studs (for wheels!)
    Sue
    I got a set of extended studs for my Cabrio from http://www.speedshack.co.uk/ they are really helpful and knowledgble guys. They may be able to supply what your after.
    John
    • KitCarGirl
      • 720
      Thanks John
      I'll give them a go :-)
      • KitCarGirl
        • 720
        I think I have found some through http://www.merlinmotorsport.co.uk/
        If they are wrong that will give me three sets of incorrect ones now! They look pretty right though. Speedshack only had the longer ones.
        • KitCarGirl
          • 720
          Doh! Wrong ones again. They were exactly the same as the long ones I had before.
          There must be somewhere I can get the shorter ones!
          • csjcarolyn
            • 157
            Sue I bought mine from DemonTweeks, the splines were OK but the studs were too long - just needed cutting shorter.
            Good luck Roger
