Pinto carb tuning
  • patrick.bramman
    • 29
    Pinto carb tuning
    I have a 1983 2 litre pinto engined roadster and I wonder if anybody has experience of re-jetting the carb. It's the standard twin choke weber and as I am running a piper cross foam air filter and a less restrictive exhaust I wonder if I should be increasing the jet size a bit?
    A plug chop shows the plugs are a bit on the light side but not excessive but with a less restrictive intake/exhaust I would have thought a bit more fuel would be in order.
    If so how easy are they to change?
    Re: Pinto carb tuning
    Easy enough Patrick.
    six screws release the top cover. Then the jets can be removed using a flat blade screwdriver. The chokes are push fit. I suggest you contact the local Webcon chaps who may be able to advise on the new size.
    • terryreed1664
      • 257
      Hi Dane, I would have a word with Bob Jackson (Penrith) he's just modified his and it go's very well. Or look back through the forum and you'll find his wright up.
      Terry
