Fuel Tank
    Fuel Tank
    Can anyone tell me the capacity of the MK1/MK2 Escort van fuel tank? Also whether the MK3 will fit? Many thanks Adrian
    Re: Fuel Tank
    Escort tank is about 8 Gallons I believe, don't know about Mk3 though as regards fit
    • KitCarGirl
      • 720
      Re: Fuel Tank
      Hiya
      It's actually closer to 7.5. Feels like 3.5 at the moment, the way I'm getting through petrol!
        Re: Fuel Tank
        Thanks for the information from you both. Sorry to hear about your thirst Sue. Maybe a couple of weeks on the wagaon might help.Anyways I was just trying to work out what fuel I should need to get me to Le Mans as my fuel guage doesn't work to well.
        • lizbillings
          • 828
          Re: Fuel Tank
          Hi Adrian. I should fill up in France. Will be cheaper. Its reading 118.9 on filling station here for diesel. Regards Liz
            Re: Fuel Tank
            Sue
            Is there any relationship between your Berli's thirst and your fondness for speed camera's or is it just down to getting the stiletto's stuck in the floor?
            • keith_h
              • 549
              Re: Fuel Tank
              Hi Adrian,
              Does the Escort tank have a swirl pot or baffles. I didn't know of the problems of low fuel and fast left handers when I installed my plain tank and it is quite unnerving to have the engine start to splutter when you are least expecting it.
                Re: Fuel Tank
                Hi Keith, My tank has baffles hence my question whether the MK3 would fit as I have been told they don't suffer from the effect you mentioned.
                • KitCarGirl
                  • 720
                  Re: Fuel Tank
                  Hi Al
                  I think it's the stiletto's getting stuck. The cameras are my enemy at the moment so I have to keep my head down or I won't be on the road at all.
                  Oh, and the fact that "me rings 'ave gone" doesn't help with the fuel burning.......
                    Re: Fuel Tank
                    Just had my rings re-done.
                    "OOH! Matron"
                    Not run the engine yet
                    watch this space!
                    (but don't hold your breath!)
                      Re: Fuel Tank
                      Due to porosity in my tank I've just made a new one with much larger capacity, about 11gal. and at the same time enabled the tucking up of my Ex. system to give better clearance. I've also managed to keep the toolbox that I origionally fitted on the N/S alongside the tank despite the larger capacity and although slightly taller,1", most of the extra capacity has come from making it square instead of the rounded shape of the origional and lowering the base and reshapeing it. The shape of the bottom also tends to keep the pickup pipe in fuel even when the petrol is down to less than half a gal.Some pics. attached to give you the idea.
                        Re: Fuel Tank
                        Pics didn't go. Will try again.
                          Re: Fuel Tank
                          Still no pics. All less than 200k and jpg.
                          Sue????
                            Re: Fuel Tank
                            Try one at a time
                              Re: Fuel Tank
                              Still Zilch. Time for the IT squad methinks. Over to you Sue.
