Propshaft
  • bryannewell
    • 331
    Propshaft
    Hi folks
    Have just bought propshaft from Autoprop
    (Ford type 9 to Marina Diff)
    The diff flange has different hole spacings to the prop flange,Did the Marina have different hole spacings on some models or did Autoprop get something wrong? I will ring them Tommorrow but some info from you knowledgable lot would be helpful.
    Spacing on my Diff flange is 2 5/16" and 1 9/16"
    Prop flange they sent me is 2 3/8" and 2"
    Bryan
  • patrick.bramman
    • 29
    Re: Propshaft
    Hi Bryan
    I wouldn't count myself as amoung the knowledgable ones but I happended to be under the car this morning and the two figures you quote certainly match my car ie 2 5/16" and 1 9/16" between centres. I have a type 9 to a BL diff (Triumph/Marina)so I guess the propshaft is wrong.
    • bryannewell
      • 331
      Re: Propshaft
      Thanks Patrick
      I have spoken to Autoprop and they asked me to measure diagonals accross holes and they would sort it!
      I have found a flange that fits in garage so have swapped them over!
      Problem sorted,on to the next problem/s !!!!!
      Bryan
