Speedometer - advice needed
  • bbeech50
    • 44
    I have a Marlin Roadster fitted with a 1.7 'O' series, 10cwt van back axle and 14" wheels. If I fit a speedometer from a midget or a B, I expect I will need to have the instrument recalibrated. Any advice?
    • 590
    Re: Speedometer - advice needed
    Brod,
    I have used Speedy cables in the past to recalibrate a Triumph Speedo from a Spitfire.
    http://www.speedycables.com/
    However, when this broke many years later I recalibrated the replacement myself. This is easy these days if you have a Sat Nav system as these tell you your speed. The needle in the speedo rests a gainst a pin when the car is not moving. This is because there is a spring that offers resistance which in turn dictates the position of the needle. You simply need to take the speedo apart and increase or decrease the spring resistance until the speedo reads the correct speed. In the case of the Triumph speedo you just rotate the needle on the spindle. However, this will not adjust the error with the mileometer as this is gear driven.
    • bbeech50
      • 44
      Jon. Many thanks for the advice. I will give it a go. Brod
