Roadster Inertia Reel Seatbelts
    My SWB Roadster Chassis 2691M 1984 has fixed seatbelts.
    I want to fix inertia reel belts as fixed belts make changing drivers laborious as two belts need adjustment each time.
    I have two slightly different drawings of a shoulder post that raises the height of the seat belt mount to the cockpit rim for later chassis numbers.
    This will also help the few old roadsters still in build that need SVA approval.
    Has anyone got a dimensioned drawing or even the real thing that I can copy from?
  • bbeech50
    • 44
    Re: Roadster Inertia Reel Seatbelts
    If there is a drawing kicking around, I would be grateful if you could copy it to me also. A rough sketch would be good enough. I can then make a drawing and make it available. Brod
      Brod. If you contact me on 0120875977 we can meet up . I sent one of the drgs. to Steve and have the origional build manual design. Hugh in Bodmin.
        Is this image any help?
        • bbeech50
          • 44
          Hi Cameron. Photo is useful. Thank you. Hugh. I regularly get to Bodmin Magistrates' Court when representing clients. Will call you at some point. Thank you for your kind offer. Brod. Porthleven
            Ought to have said thanks to Hugh for sending me one of the build manual drawings. Now Cameron has added a third option that requires much welding on my old Roadster.
            Brod, if you come up with anything please let me know.
            I am trying to get the 13 Sussex Marlin owners together, in 11 years I have only met one. That may give me a real look at another old roadster.
            Thanks guys so far but keep me in the loop.
              If this dosnt work I will email it to Sue to put on
                Sue seems to be busy.
                You can contact me at stevejgreen at btopenworld.com
                • KitCarGirl
                  • 720
                  Hi Guys
                  Sorry I missed this until now. Work has kept my head down rather more than I'm comfortable with but I think I'm out of the trees now.
                  Ben, your image was a powerpoint and they can't be loaded. It needs to be a jpeg. Is this sorted now??
                    Hi Sue, Yes dont worry I emailed it to Steve.See you next weekend BB
                    • andy4
                      • 77
                      My Roadster already has inertia belts, so no need to chassis mods, but can anyone advise on the best replacements ? The build manual mentions Britax AC3001, but I think Britax don't do belts anymore ( now IMMI ? and no car belts listed ) - I am guessing securon are the ones to buy - possibly 500/15 model - anyone fitted these ?
                        Securon were originally fitted to my Roadster so no brainer to start there.
                        Securon 500/15 was my choice. Not ordered yet but CBS were the cheapest from my research, but no choice of pretty colours.
                        http://www.cbsonline.co.uk/standard-retractable-short-stalk-150mm---sec5s-812-p.asp
                        I have been looking at mounting methods whilst it has been raining. I think it will be a winter job with both seats out while I get strengthening plates etc. fabricated.
                          Am currently working on the lower mounts for my seatbelts. (YKC ROmero) inertia reel and top mount ok (as in pic above) but where should I mount the lower bracket? Can I attache it to the side of the chassis in the rear corner? I was going to mount the other bit (the stalk)on the seat - put a piece of angle or box across the chassis to ount the seat runners on first though. Any thoughts?
                            piccy of rear of passenger compartment
                              Is the arrow in your picture the spot that you intend to put the outer fixing? If so its pretty much the same as the Roadster.
                              On my car the inner stalk is bolted through a corner reinforcing plate as in the picture, taken from the underside. Personally I think that its a little weak but there are no other practical options apart from a larger corner bracket.
                              I would be reluctant to follow your thought of fitting the stalk to the seat and then relying on more fixings, I would prefer securing it directly to the nearest chassis member or a tub strengthening plate.
