Overdrive Wiring
  • tomallen_2003
    • 91
    Overdrive Wiring
    Hey everyone
    I looked at the wiring on the overdrive and couldn't make tale end of it as it was all the same colour. So has anybody got a wiring diagram or know how the overdrive is wired on a 2500??
    Re: Overdrive Wiring
    Hi Tom, There are two systems depending on the overdrive type. Have a look on the side of the actual overdrive unit and it will be either a D or a J type. Email me your email address and I will try and scan the appropiate drawing. I cant seem to get these drawings to fit the forum.
    • KitCarGirl
      • 720
      Hi Ben
      Try saving the scan as a jpeg then it should load. I have a website meeting soon and will see what we can do about getting scanned images on the site.
      • tomallen_2003
        • 91
        Hi Ben
        I had a look at the car yesterday and i couldnt actually see the plate but have enough room to do the wiring. I can see the top and the bottom is there any way of telling the difference?
          Hi Tom
          Sorry for the delay I have been on the Derby weekend and only just got back into the forum. I have had to do some more homework and I have your email address I will try and send you some info in the next day or two
            Hi Tom, If all else fails try< www.Triumphspitfire.com > and have a look at the overdrive section.
