reverse
  • Ryanhooley
    • 53
    reverse
    Can anyone tell where reverse should be located on the gear lever?
    Ryan
  • bbeech50
    • 44
    Re: reverse
    Which engine/gearbox configuration?
    • Ryanhooley
      • 53
      Re: reverse
      it is a marina engine and box.
        Re: reverse
        Most likely is either press and push left and forward or lift and push right and forward. It will be in one of the corners! ;-)
        • terryreed1664
          • 257
          Re: reverse
          Hi Ryan,
          Nothing to do with gearboxes. Check out this head gasket set for your fiat t/c on ebay item number 310080536098.
