I am still pursuing my hot running saga (see next Pitstop / rich running sequel). I fitted a Kenlowe 13" series 2000 fan some time ago and apart from blowing fuses (now sorted by higher rating slow-blow type) seemed just about enough to cope. Since fitting the Optimax chip and Lambda sensors driveability is dramatically improved and fuel consumption has decreased dramatically, thank goodness! However the trade off is that the weaker mixture causes higher running temperature. It will just hold 85degC on a really cold day if the heater is on first switch click. Any warmer ambient and I need the heater on second switch click. Following slow traffic full heater and Kenlowe on will only just about cope. I fitted a new thermostat as a precaution with no improvement. Rover only list one t-stat / temperature for the 3.9i L/R Disco! No winter / summer / export variants listed!
Have now removed the MOC badge, badge bar and relocated the spot lamps from “standard” location to hang them under the headlights, all in pursuit of getting “clean” air straight into the radiator. Rad is Marlin 3row X-flow type. Currently modifying standard Hunter grille to be "front removable" for instant access, so I can pull the fan forward to stop the motor blocking the core. Addition of rim seal around fan outer diameter to fill the resultant gap and a construction of a Ram Air box to force all the air through the rad core, rather than around the rad, will hopefully stop the fan cutting in during normal driving.
What fan size, make etc do other V8 owners use? Is cooling adequate or marginal? Does anyone else have fuel injection? I have seen a Cabrio and a Berlinetta in the past with an additional radiator underneath the front. Is this in the main coolant circuit or in the heater return circuit? If in the main coolant circuit does the standard water pump / pulley size give adequate circulation? Some advocate replacing standard rad with an Aluminium one. Very pricey! I still favour the extra rad as it would further add to the coolant capacity and slow down the temp gauge needle! All ideas / comments welcome. Peter.
