Rubber extrusion
    Rubber extrusion
    I'm looking for a supplier for some U-section rubber extrusion to go around the outside of the wings to get the radius within SVA tollerances, any ideas? it ideally needs to be 5mm internal size. I've looked at the Woolies site and they have some with 1.5 and 2mm internal size (which would do to edge the bonnet.
    Any suggestions would be welcome.
    • 1644
    Re: Rubber extrusion
    Hi Chris. There is a chap who goes to all the Kit Car shows who is based in Uffculme and has loads of this sort of stuff. His hand-out is on a sheet of blue A5 paper which I cannot find at present as I have just had a clear up! I will let you know if I find it. Meantime have a look at www.carbuildersolutions.co.uk as they do some self grip edging up to 5mm panel thickness. If the "grippy bit" is rubber it would be removable later ;-) without damage as long as the paint is really hard. Peter.
      Chris
      Have a look at www.sealsplusdirect.co.uk
      • christel.stockden
        • 24
        Hi Chris,
        For even MORE choice have a look at www.coh-baines.co.uk
          Thanks for the info. Bits ordered from carbuildersolutions. They were most helpful for suggesting what extrusion to use.
          Now to try to get the car ready before 29th April when the SVA becomes IVA and the price goes from £160 to £500!
          • donsayers
            • 282
            http://www.woolies-trim.co.uk/
            • marks
              • 33
              Are you sure you need rubber on the wings. I didnnt need it, but i took lengths of seal from old sierra door frames(metal mesh core and fabric/rubber outer in case. good luck
                I think you need it on the front edge of the wings unless you radius the sharp edge
