Marina 1.3 bottom hose
  • FranklinLeicester
    • 380
    I have to replace this hose. Can I assume it will be a standard Marina item despite the fact the car has a Vauxhall rad?
    Franklin, Leicester
  • daniels917
    • 106
    Re: Marina 1.3 bottom hose
    Hi Franklin, the build book says standard hoses are suitable with a little trimming. good luck with it Merv
      • 590
      Franklin. You might find this hose difficult to find. Most builders use the flexible type from Vulco. I get mine from the local auto factor but you can also get them here...
      https://www.europaspares.com/HEATERS_and_DEMISTERS/DUCTING__VALVES__and_HOSE/VULCO_FLEX_RADIATOR_HOSE_3593.html
      They work very well.
      • FranklinLeicester
        • 380
        Thanks for your help chaps. Got it sorted. Local factor had one in stock. Fitted without mod. Jon, I really wanted to use the original style hose as it has the "spur" hose for the heater connection.
        Franklin, Leicester
