Valve spring compressor tool
    Does anyone have a Valve spring compressor tool I can borrow.
    The one that you can use without removing the cylinder head. I just want to replace the stem seals.
    Re: Valve spring compressor tool
    Cant help with the tool but its possible to fill the bore with stout string and wind the piston up to hold the valve.
    Having removed the rocker gear make up a bar that will use a pedestal bolt as pivot with a hole drilled to match the top of the valve stem position.
    Then you can press down on the free end forcing the spring/valve cap down to remove the collets through hole in bar. Gently release and remove spring etc.
      I was planning to do the rope trick anyway as a safeguard to dropping a valve.
      I just thought the proper tool would complete the job quicker, perhaps only requiring the relavent cylinder to be at tdc without the use of the rope, than a home built tool that you describe.
      I might also try the same job on a Toyota Supra straight six with 24 valves, a slightly larger project requiring cams out etc...
      • keith_h
        • 549
        I don't know whether it is too late but I recently gave one to Adrian Bull- you might like to try him
          • 2447
          Yep I have it. Give me a bell on 07809 403112 and we can arrange a pick up point. P.S. have only just seen this so sorry for the delayed reaction. Adrian
            Adrian: Thanks for offer but I should have one in my hand on Saturday.
            If it goes wrong I will call you Monday.
              Adrian: Try me as stevejgreen at btopenworld.com
                • 2447
                Steve, find attached pic of both items, ket me know
                  Sorry Adrian, Nice try but the same as I have already been offered and the same as what I already own. They need the head removed and I dont want to go do all that work just now.
                  The type I was looking for is as in the picture. You remove the rocker shaft and then do all the work whilst the head is on the car. (See picture for an example)
                    • 2447
                    wow, that looks complex and expensive. Sorry I wasn't able to help. Good luck
