Lwb roadster weight
  • tara521g
    • 17
    Lwb roadster weight
    Hi,
    Similar problem to the one others have had, my roadster is booked in for mot and they have asked for its weight, I don't really want to drive it to a wighbridge as its not been on the road for 15 years and is largely untested, hence the MOT.
    Its a LWB 1.3 a series roadster, has anyone out there weighed one of these?
    How accurate do the testers want it to be? can i give them the rough figure from the original brochure info?
    cheers
    Jon
  • lizbillings
    • 828
    Re: Lwb roadster weight
    Hi Jon. Seeing the weight of a SWB is about 740kg, I think if you said about 750kg the MOT testers would be happy unless they want an accurate weighbridge ticket. Good luck with MOT
      • 2445
      Hi Jon, Had the same situation with my Roadster. They require the info so that they can check the braking efficiency. I used the information in the brochure and they were happy with that. Didn't need a weighbridge ticket. Adrian
      • daniels917
        • 106
        Hi Jon my test station has a set of weighing pads on the tester, and my SWB with a pinto 2.0L always comes out at 740Kg with a driver. hope this helps (ps my brakes were 117% efficient this year!)Merv
        • tara521g
          • 17
          thanks everyone, I shall tell them about 750kg, the mot chap seemed happy without an offical print out of the figure.
          Thanks again
