Wiring Diagram For Sierra on CAD
    Some time ago I am sure I read on MOC forum that someone had the complete Sierra wiring circuits on CAD?
    I have reached this point and will need all the help I can get, so a copy of this would be very welcome.
    Re: Wiring Diagram For Sierra on CAD
    Should have added, I think the owner of K629 RGO may be able to help? I believe I spoke to you at Stoneleigh last year and you had a CAD version of the complete wiring diagram?
    • djj_engineer
      • 405
      Hi Mike
      I have a wiring diag I made for my Cabrio but it has a V8, and will therefore be different from the Ford engine.
      If it is any use you are welcome to a copy
      Derek
      • keith_h
        • 549
        Mike, if you can't track down a cd then I have the whole lot photocopied. You are welcome to borrow/copy it but I will need it back.
          Any electronic versions on CAD would be welcome - I have a BMW engine so that part of it is not relevant.
          Thanks in advance for anyone who sends any drawings to:
          mands dot garner at btinternet dot com
            Hi Mike,
            PDF versions of the wiring diagrams taken from the Haynes manuals are available in various web sites including this one.
            http://www.siipicossu.com/manuaaleja/0903-wd.pdf
            Not quite a cad version but you might be able to get the info you require.
