Hi all, newbie to Marlin here, just bought the 5Exi-R ex-demonstrator!!
At present it has 195/50/15 tyres which with the Honda gearbox give it quite a low gearing as the Type R has 205/45/17's, I believe.
I will probably keep the fronts the same but I 'm wondering what size tyres any of you have fitted that are larger than 15's. My main concern obviously is fouling the wheel arch but looking at the clearance I think I can get away with up to 215/50/16 ( that is a 4.5cm greater diameter)That tyre size is very close in rolling radius terms to the 205/45/17's. I want to fit Toyo R888's so a 195/50/15 front and 215/50/16 rear combination would be perfect - if the rears will fit!! Cheers Alan
