key-cutting or supply
  • gouldsborough7
    • 393
    Guys
    My Hunter came with only 1 set of keys: boot, petrol cap, engine compartment, ignition/door & security fob.
    I suspect that I can get most of them copied at a High Street shop, but am not sure about the round ignition/door key + the security fob. The original owner confirmed that she lost the spare set.
    Anyone had experience and/or trouble sorting out a spare set? The security fob is a pain to use, and I wish I could get rid of it. In the meantime, I had better get a duplicate.
    Any ideas, guys?
    Re: key-cutting or supply
    If the ignition key is a Ford one without a coloured part then your Ford garage could supply a new one easily.
    The other keys could be probably copied in a high street shop, but you will have to approach the manufacturer of the alram/immobiliser to get a duplicate of the fob.
    • gouldsborough7
      • 393
      Hi Chris
      That's similar to my thoughts. I suspect that my only problem area is the fob. I've no idea who made the immobiliser system. (Does it work as an alarm as well?) What's the bet that I don't get any answers if I approach Marlin?
      I'm half tempted to glue the fob in its socket. Not sure if the system would work then. Anybody any ideas on the fob or the alarm company?
      • gouldsborough7
        • 393
        Chris
        Took sponge out of fob-socket, so now fob can stay in socket until I want to make the car extra thief-proof. Solves the problem of the daft start-up procedure as well!
        Got the petrol-cap and boot-lid keys cut, but shop didn't have a spare blank for the engine lids. Was pleased to learn that the Ford Ignition/door key can be copied, but the key-shop guy said their equipment was bust. "When will it be fixed?" I asked - "sometime never" was the response.
        So will be trotting around another key-shop or three, knowing how things go.
          Your Ford garage may be able to supply you with a key. My donor Sierra came with only one key and I took it to the spares department, the chap looked at the key and muttered up-down-down-up-up and went of and got a new one, just like that.
          Chris
