Having been used to the high performance of my Skoda Octavia brakes, each time I get back into my Hunter I have to re-adjust braking distances and brain, as one might expect with old technology.
Recently, on braking, the car has developed a tendency to pull to the left. I mentioned this is a previous message, and got a few suggestions to check & sort this out. I will shortly be checking out all of the basics, and hopefully find that the cure will involve no more than a replacement of the off-side calliper. If this is the case, I will probably be tempted to replace both of them to ensure a balance. The front pads have stacks of lining material left, so do I keep them? Although they have done only 9,000mls, should I replace them with really some grippy stuff? With a low annual mileage, it wouldn't matter if the material wears down quicker than normal. Anyone know where to buy such pads?
The car was built with 1998 Ford technology, and still has drum brakes at the rear. So any changes to be there?
So then I got to thinking that possibly I should be thinking about beefing up the whole brake system? Compared to regular cars, the servo is quite small. I also read (in an old Forum message of 1995)somebody was suggesting an up-grade of master cylinder size.
So there's my dilemma - starting off with 'pulling to the left' and ending up with wholesale replacement of all or part of the brake system.
Has anybody got any fairly economical ideas on tweaking up my brakes?
