Marlin special axle U bolts
    As part of my Dolomite axle install I need to replace the axle U bolts that were an original Marlin part.
    The Marina axle was lowered by Marlin special tapered blocks so no standard Marina parts are long enough to fit.
    Does anyone have a source of these U bolts as they are all likely to be 25 years old, and rusted and weak like mine.
  • donsayers
    • 282
    Re: Marlin special axle U bolts
    You'll be lucky. I had to use Mark One Escort ones can't remember here I got them though. it was on line. The holes in the mounting plates will need to be enlarged.
    • CosworthCabrioLee
      • 924
      Steve,
      The best bet is to get these made to your sizes on your car and block heights, Just made so for one of my roadsters. A good machine shop should be able to do this for you
      • andy4
        • 77
        When I bought my new springs I got some bolts at the same time from http://www.jones-springs.co.uk/home.htm - must admit I took my lowering blocks out as I was raising the back for trialing, but the may well be able to help you as the seemed to have a supply of most sizes.
          Thanks guys. I didnt want to use escort units as it would mean drilling out the plates etc and they would need further bending to give a snug fit around the axle.
          Jones can do them but the price is frightening for a set of 4. Near enough £10.00 each.
          The price will drop significantly if others would like some for future use.
          Are there any takers out there, for a group buy for everyones benefit.
