Hi, I have read several old threads on Fuel fillers etc but they dont quite answer my question :- if possible I need to know what fuel filler neck and cap can be used on a Berlinetta that will pass the SVA.
I have seen the many Aero Type caps / fillers on sites such as CBS but they seem to need a 120mm flat area and this does not exist on the rear area of the kit, is it still possible to use one of these commercially available caps? if so which one did you use?
Many thanks in anticipation
Malcolm
Malcolm
