AVO dampers, front and rear
  • mlincsmit
    • 63
    I'm fitting new dampers to my Marina based SWB Marlin - anyone fitted the AVO adjustable dampers. Would love to fit coil overs but lack of room prevents this - Model numbers would help and are they preferable to Spax? - Mike L-S
  • CosworthCabrioLee
    • 924
    Re: AVO dampers, front and rear
    Mike I have AVO dampers on my car at the front and they are very good. Also some time ago I once had some rear shocks with coil overs fitted but removed them to fit a pair of spax
      I have Gaz adjustables at the front and they are much better than the Spax I had before...probably because they have poly bushes rather than rubber. Rears are Spax.
      • mlincsmit
        • 63
        thanks for your replys, what part no. are your AVO fronts Lee? and why did you replace the coil overs at the rear as this was a thought I had of doing - Mike
        • robcawte
          • 68
          I bought a pair of AVO's for the front of my Berniletter. After a week or two I looked to find the thread had striped on one of them. AVO would not take them back untill I had taken the spring off, which is now not safe to do. Needless to say I do njot have a good word to say about AVO. Bob
