Roadster Side Exit Exhaust
    Message originally posted by: Anthony Baker
    I currently have a rear exiting exhaust on my 2.5 6 cylinder Triumph based Roadster. l would like to fit a side exiting exhaust to gain more ground clearence. Can any one offer any advise please.
    Re: Roadster Side Exit Exhaust
    Message originally posted by: Ben Caswell.
    Assuming your car has a cast iron manifold its possible to cut the down pipe under the flage shorten the down pipe and turn out so it exits over the chassis about 6 to 10 inches infront of the footwell.I have used a cherry bomb muff diver(honest thats what its called) and a elbow just in front of the rear wheel,sounds reasnably ok gurgling 6. I would recommend sticking an insulation mat to the wing above the box.
    • paulhyder
      • 141
      first line last word should read flange
      • me
        • 23
        www.merlinmotorsport.co.uk do "make your own" exhausts with silceners and what not, YKC also sell the bits for the roadster at least but they are slightly pricey imo.
        • cabrioman
          • 309
          Cut and welded mine from surplus landrover pipes and used any new silencer I could make fit (Moggy thou one was a bit restrictive)
