I am now stuck with no Tank filler pipe grommet for the MkI, can ayone help with where to get one please. The pipe is 2.25" diam. I expect to have to make the outside edge cut to fit the body. It is a MkI with the hole in the middle of the boot area. The old one was in 25 pieces and glued in. !!! Back end now fully back in, pics on the website !! Greg Pearson
Petrol Tank Rubber Grommet Mk I
Tags: None
Re: Petrol Tank Rubber Grommet Mk I
hi gregg unsure of dimensions but try this
http://www.rimmerbros.co.uk/ProductImages/Large/CRC1996.jpg
its on the rimmers website just search for fuel filler grommet
Thanks. Item is for an SD1. Ordered and awaiting delivery. Exciting ain't it !!
ThanksAttached Files
Spitfire one would have done the job as thats what your tank is probably from.
You may have to open out the recess in the grommet as GRP is a bit thicker. BenBen Caswell probably not the last word on anything here!!
