Tyre Pressure Survey
  • greatoldone
    • 155
    Guys - I wonder what everyone is running with. I seem to recall that 22 psi was mentioned way back in the dim and distant past as the Marlin 'standard'
    I did have mine at 25psi, but jacked it up to 30 for the IVA test for a little extra self centering.
    Does anyone know how to calculate the optimuim pressure? I guess it'd be based on the weight...
  • copperleaves11
    • 328
    Re: Tyre Pressure Survey
    Hi Jason. I run 18psi front and 20psi rear, using 215X70X15.Hope that's some use to you.regards
