I have an MOT!
  • djj_engineer
    • 405
    Re: I have an MOT!
    Hi Guys
    I guess I must have the only V8 that doesn't run hot. Don't ask, I don't know why! It has always been well behaved. I do use the standard SD1 manifolds so they may not contribute as much heat as the Stainless/tubular ones. It does have two seperate exhausts but I can't see that they will make much difference.
    • sam.pej
      • 71
      Re: I have an MOT!
      Hi All
      Have fitted an oil cooler and had louvres cut in bonnet. Seems to have helped, temp stays under 100C now, probably about 95C but have not done any great distance yet. Bob, that scoop and ducting sounds interesting!!! Hope to be at Stoneleigh so may see some of you there. Cheers, Paul
