Rear Exit Exhaust box
  • paul17
    • 8
    Dose anyone know a make of small exhaust back box that could be modified to fit onto my Roadster exiting out the back in a space roughly 120mm diameter by 500 mm long (box dimentions), the pipes could be sorted out later.
    Has anyone got any ideas what i could use.
    Thanks for any help.
    Re: Rear Exit Exhaust box
    A TR6 back box is approximately that size?
    • CosworthCabrioLee
      • 924
      Hi Paul
      I have a small box on my roadster that is at the side of the tank and the pipe goes over the exhaust then under the floor I will get some photos tomorrow.
      • CosworthCabrioLee
        • 924
        Paul pictures as promised the car will be at Stoneleigh if you want to crawl under it
        • paul17
          • 8
          Thanks all for your help, might see you at Stoneleigh.
