Ride height
  • bryannewell
    • 331
    Ride height
    Having justcompleted rebuild of Marina based LWB RoadsterIfind there is not enough ground clearance to sump(2ltr Pinto)(Hence myh plea for a new sump in miscellaneous if anyone can help!!)
    Idont want to raise engine at this time as it only just fits under bonnet now
    Would removing lowering blocks at back and winding up the adjusters on the torsion bars be worthwhile and or changing to 14" wheels
    (now 13")
    Any other worthwhile options please?
    Bryan
    Re: Ride height
    How much clearance have you got? It wasn't a problem with my son's pinto engined version. Alloy RS 2000 is I believe shallower but you need the appropriate oil pick up pipe and don't forget the dipstick. Alloy one on e bay but are getting expensive now.
    • CABRIOBOB
      • 478
      Re: Ride height
      Bryan, You can shorten the sump or fit one from a Capri with OHC engine as they are about 1" shorter then a Sierra OHC engine.
      • CABRIOBOB
        • 478
        Re: Ride height
        Also adjusting the torsion bars will help but you might have to reset the tracking, also fitting 15" wheels will help. Is you current sump level or below the gearbox bell housing ? as A capri sump is just above/level the bell housing.
          Re: Ride height
          Surely changing to 14" wheels will have no change in ride height, it's the tyre profile and hence rolling diameter that will change the ride height.
          If larger rolling diameter tyres are fitted all round this will also change the accuracy of your speedo.
          • pearwood
            • 36
            Re: Ride height
            go to the robinhoods web site click on links around the net the north west area. theres a great item all about shorting pinto sumps and pick up pipe i did mine you get about 3" extra groung clearance.
            bob
            • macdonald.dm
              • 531
              Re: Ride height
              Fitting 15" wheels with 65 - or even higher - profile tyres should increase clearance, raise gearing for more relaxed cruising, improve comfort significantly, have little negative effect on road holding, and will improve looks.
              Provided they fit...
              • Sidon
                • 115
                Re: Ride height
                Sorry to hijack this thread. I'm interested in larger wheels / tyres in an effort to increase the gearing of my Roadster, with looks and ride height secondary considerations. Its Marina 1.8TC based, currently fitted with 185/70/R13 tyres. What wheel and tyre sizes would anyone recommend and what wheels do you consider suit the Roadster best? Thanks.
                Roadster MKII LWB. Built 1988. Marina 1.8TC based. B Series 1950cc engine fitted with twin SU HS4 carburetors and unleaded, big valve head. 4 core Austin Maxi radiator. All Marina 1.8TC running gear including 4 speed gearbox. Minilite style 15"wheels fitted with tall tyres to increase gearing for more relaxed cruising.
                • CosworthCabrioLee
                  • 924
                  Re: Ride height
                  I use 15" wheels with 195-55-15 tires and this will improve handling, also if you go to a larger profile will lift the car without any problems.
                    Re: Ride height
                    couple of useful sites with wheel/tyre comparison tolls.
                    http://www.mintylamb.co.uk/?page=auto.htm
                    Minty has a few other goodies...SU needle comparisons & other stuff.
                    The other good site is
                    http://www.carbibles.com/tyre_bible.html
                    loads of useful info there.
                      Re: Ride height
                      It's perhaps worth discusing performance, suspension and tyre size/profile.
                      IMHO a Roadster is much lighter than an original Marina. As a result a Roaster will feel a lot stiffer as the stock spring rates are designed for a heavier car. I for one use low tyre pressures which allows my relatively high profile tyres to contribute to the spring effect. Low profile tyres on larger rims will not offer the same compliance, though when cornering will give a much better feel.
                      Its rather a question of what you are trying to achieve a generally smoother ride or sharper steering response.
                      Though larger rolling diameter tyres will improve top speed this will be countered by a general loss of acceleration. The only logical route for higher top speed whilst maintaining reasonable fuel consumption is to go for an overdrive gearbox.
                      • bryannewell
                        • 331
                        Re: Ride height
                        Thanks for all your response
                        I have about 3" ground clearance unladen!
                        First time out 2up on country roads I wore a hole in sump!
                        (now welded but I may have to leave my better half at home untill i sort a perm solution!!!
                        I am looking out for Capri sump as that should gain 1" up to bottom of bellhousing.
                        I may be able to get a small amount more if I raise engine mounts.
                        I use 13" wheels with 65 profile so maybe 15" with same profile is the way to go(inaccuracy of speedo noted Steve)
                        What wheels would be good for Marina base as per simons Q?
                        Many thanks
                        Bryan
                        • CosworthCabrioLee
                          • 924
                          Re: Ride height
                          Like I said earlier I use 15" wheels on my Roadster and this improves handling, improves ride quality, raises height. I drive lots of Roadsters on all types of wheels but would never ever put my own car back on 13" rims.
                          As for wheel suppliers try Midland wheels supplies I think they will be at Stoneleigh
                          • Sidon
                            • 115
                            Re: Ride height
                            Lee - your Roadster looks beautiful and the Minilite wheels really suit it in my opinion. It makes my Marlin and my efforts to 'do it up' look rather sad. Steve - I appreciate your comments but I (and I think Bryan) was wondering whether we could increase the wheel diameter whilst retaining reasonably high profile tyres for the reasons Lee highlights and, in Bryan's case, to stop his bottom rubbing! My car is too low geared so making it slightly higher geared would help cruising without compromising acceleration. I would really love an overdrive but I'm not experienced enough to fit one and don't know anybody who would. I need new tyres so now would seem to be a good time to go the extra yard (or £250) and get 15" wheels.
                            By my reckoning, a 13" rim with a 70 profile tyre (my current set up) has a radius of 235mm whereas a 15" rim with 65 profile tyres has a radius of 255mm. An increase of 8.5% rolling circumference. Would that result in 8.5% higher gearing or is my calculation too simplistic? I realise that the speedo accuracy would be compromised but, to be honest, it's not that accurate anyway.
                              Re: Ride height
                              Simon - use the gear-speed calculator on the MintyLamb link I posted above...it'll tell you exactly what the differences will be...the wheel/tyre one will also show exactly the differences between different combos...
