My Marlin has suddenly started to overheat. The engine is the morris 1800.
Not sure if it the Thermostat but can't get the thermostat housing off as I think it has corroded arround the studs and I am trying to get a replacement before I damage it in the removal process.
However it may be the Water pump. The engine gets hot then fills the expansion tank, which then overflows. Would this happen if the water pump was not working?
Grateful for suggestions
Derjac
Derjac
