After a bit of struggle I have obtained a Sierra Brake Master cylinder almost identical to the one used by Marlin.
On the Sierra the brake reservoir fits directly to the top but Marlin use a remote reservoir. The cylinder has two large holes with rubber washers in them, to connect to the Ford Reservoir.
Two questions:
How do you connect and seal flexible pipes to the cylinder from the remote reservoir?
Is it possible to fit a Sierra reservoir directly?
Many thanks.
Jeremy Ward
Two questions:
Many thanks.
Jeremy Ward
