straight 6 engine number
  • info11
    • 12
    I'm very new to this kit car lark but loving it so far. Bought a Roadster a few weeks back and was told it has a 2.5lt straight 6 engine, originally it was a 2.0lt but was replaced by the previous owner... but no history or proof of this.
    I need to know how to find out what it is, so where is the engine number? i have 4 sets of numbers on the cylinder head V3298 313248 X41 219016 what are they?
    It has twin SU Carbs so i think its a triumph 2500TC any help is very welcome.
  • Tnick
    • 93
    Re: straight 6 engine number
    Keith
    The engine number should be stamped on the block (rear near side of engine to the right of the distributor).
    Canley Classics have a list of engine number on their website link below;
    http://www.canleyclassics.com/?xhtml=xhtml/infodatabase/engine.html&xsl=infodatabase.xsl
    If the link doesn't work the list can be found by clicking on archive followed by technical archive followed by engine number identification chart.
    Nick
    • info11
      • 12
      Seems i've been looking in the wrong place then !!
      so what are all the numbers i can see? on the opposite side of the engine, carb side, bottom of cylinder head ?? confusing....
      • info11
        • 12
        Thanks Nick
        Found the number MM3615HF Triumph 2500TC so at least i now know what lump is in there !! Anyone know what the HF means ?
          Nick is correct that the prefix MM is for the 2500 engine
          I think if you look closely the HF is actually HE which is the suffix on High Compression engines.
