Fiat twin cam starter motor question
  • sam_no3
    • 13
    Hi,
    having a problem with the starter motor solenoid on my 2litre fiat twin cam. Rewired my roadster completely but can't seem to find where the solenoid relay switch connection is. Got the 2 main battery terminals wired in correctly. If anyone can offer any pics/info as to where the relay switch is on the solenoid that would be great as i'm running out of ideas now,
    Cheers,
    Sam.
    Re: Fiat twin cam starter motor question
    Hi Sam,
    there's the heavy one to the motor windings, another to the battery, and a spade connecter between them for the feed from the ign. to operate the solenoid
    • sam_no3
      • 13
      Thank you very much Hugh, just found it and connected it now. Couldn't find where it was anywhere from the haynes manual or anywhere else on the internet, saved me a lot of work!
        Sam, I take it you sorted your your propshaft problems.
